yes ive had a read, but doesn't go into any detail on the charger service ?Have you reviewed this :
The Complete M271 Engine thread. ( Revised and Updated )
People are forever asking about how to mod their M271 C180 Kompressor so I thought some work was required to help guide us all! Hope this helps someone.
As you know a number of people regularly ask about the M271 engine on this and other forums. Mercedes made this engine in such away as it can be configured to provide different outputs and therefore has been used in many different guises and models.
BACKGROUND
The new W204 C Class uses the engine as does the W203 C Class. But Mercedes...
I’ve done mine twice , using Mobil Jet Oil 2 i believe, I’d have to check . You can normally buy kits on eBay for £20 ish .anybody service (oil change) their chargers ?
cheers bud, just another job to doThere was some stuff on YouTube if my memory serves me .
There are a couple of pipes to remove at the front which gives you access to the tiny fill screw , wedge a cloth in the gaps below it I don’t think you can buy them separately.
A mechanics mirror might be handy to help you see it .
You drain it buy using a syringe and tube , it is hard to find the sweet spot for drawing the oil out , but when you do leave the tube where it is and pull the syringe off to get rid of the old oil .
Refill with fresh jet oil until it runs out then replace the screw thingy again , I think there is a tiny o ring on it .
I did mine at 50&85 k miles .
A lot of the mini forums recommended doing it , I think MB use the same Eaton supercharger .
Summer job in a t shirt with the “guns “ out buddycheers bud, just another job to do
yep, this cars gona keep me busySummer job in a t shirt with the “guns “ out buddy
yeah it'll keep my busy alright !!!!!This is the link for the W203 C200 Kompressor with M271 engine and supercharger.
Mercedes Benz C200 (W203) Eaton Supercharger Oil Refill Kit 2003 2004 2005 2006+ | eBay
Powerhouse Automotive (UK) Ltd is based in Chesterfield, England. - 135ml of the oil in a reusable 200ml plastic bottle. Helpful Links. Aston Martin Performance. General Bike Spares. Dynojet & K&N Products.www.ebay.co.uk
Probably the same as above.
Another job to be done when the weather improves.
This car will certainly keep you busy !!
Diff oil , easy cheap job using Fuchs .yeah it'll keep my busy alright !!!!!
list of jobs......
gearbox service
2 rear tyres
both belt pulleys
belt
ESL bypass
new key (only got one)
cam magnet wires (fitted)
hopefully nothing else ??????
yep and that but it could go on with ALL the fluids !!!!!Diff oil , easy cheap job using Fuchs .
