mb diesel injector's photo?
caddy
hye evry body i'm new on this forum.
i'm asking a question for the MB pro! :D
i'm serching an injector for an indirect injection (like 300td) who have a position sensor.
any one here know if is there any MB fited with this sort of injector?
thaks to all.
I took my injectors out yesterday and had them tested, they dont look any different to any other injector I have seen. Did not think to take a photo of them.
all the injector are same injector ?
All 5 on mine are the same, I expect they are similar to the 300TD but the CDi's would be different.
thanks! for your answer!
As others have said, there is no start of injection sensor. The timing is set manually using either a dynamic timing light or statically using a timing device through the port in the pump body.
Why are you looking for a sensor in the first place?
