MBUX Dashcam USB Options
Headhurts
Near Coltishall, Norfolk
Mercedes GLC
I have a 2021 GLC and following an update to the MBUX system the inbuilt Dashcam option is now available at a one off fee of £200, I wonder if anyone on the forum can answer this fairly simple question as I cannot find anything via searching forums or web.
The camera records to a USB device so once recording is started can I also access another USB device containing my music or will MBUX only allow access to one device at a time.
Many thanks,
Robin
Yes you can have two or more. I have this system in my new C200. I am currently using two USB sticks in the slots under the main display, one with a folder containing music files and another with a speed camera database (from SCDB.info). The built in dash cam records to both which could be a bit confusing if/when you need to look for a recording and I can't see if it is possible to specify which is to be used. One other point: Sometimes the system seems to get confused and when I select "Media" to play music, it displays the recorded dash cam videos (!) so its necessary to go into Settings and select the correct USB and folder containing music.
