Triplesilk
- Mar 7, 2016
- Mercedes C180
Hi all, I wonder is anyone can give me a steer on what to do. If the answer is that I have to take the car to a dealer then fair enough, but I like to try to fix things myself as far as I can first so I'm keen to try anything that I can.
My car is a 2002 C180 estate. The passenger side wing mirror indicator no longer works, and I get a warning on this on the internal display panel.
There was a bit of damage on the plastic cover of the bulbs, but nothing much, though it may be that a slight bang caused the issue. Anyway, I bought a new part (which is the whole plastic unit, with the four bulb inside) and fitted that. This does not fixed the problem though.
I notice that the inside controller where I can change the angle of the mirror glass when sitting at the driver's seat doesn't work either, though the whole mirror unit can be closed or opened automatically from inside the car.
When I fitted the new part I had a look at the wiring and nothing obvious was wrong. When the mirror cover gets pushed back in the connection is made on contact. I can't be 100% sure that this is being lined up but it seems like it is, but in any case this may not (?) effect the mirror angle control so it made me think that something else is the issue.
Anyway, any kind of steer would be great!
