Mercedes C270 cdi 2003
Graham1977
Durban South Africa
Mercedes Benz C270 cdi
Can anyone help me identify relay k on the fuse box under the bonnet or give me a daigram of it for a mercedes c270 cdi 2003 model
Can't see any reference to a 'k' relay, but hope you can identify it from this first picture. I've attached all fuse boxes in case you should need them at any time.
If you need wiring diagrams....... shout......and state which items.
You should find a fuse map hidden away in the driver's side fuse box.
Open the driver's door fully, prise off the end of the dashboard (it should clip off with a screwdriver or suchlike), and there will be a fuse panel revealed. There should be a map of all the fuses and relays folded up in a neat little compartment.
Relay K is next to the ecu under the plastic cover on the w202,chances are its there.
Copy of fuse chart, in case you need it.
