Hello
Iv just bought a Mercedes Vito 2007 with 72k on the clock. Very happy with it so far apart from its horrible to drive! Im having issues with the gearbox, 1st to 2nd and sometimes 2nd to 3rd is the issue.
Its mainly 1st to 2nd, when i go from 1st to 2nd i get a slight crunch, it doesn't do it if i slide into 2nd really slowly or if i really smash it into 2nd but only when doing a normal gear change (which is so annoying!) It goes 3rd to 2nd fine and all gears feel good when the engine is off.
iv read a link online about changing the gearbox oil -
Poor First Gear Selection - Manual Gearbox Problem W639 Vito - Cure
and one about worn linkage -
Mercedes Gearbox Wear Point W639 - Mercedes Gen-In
I'm not a mechanic but i am not overly convinced changing the oil will fix the issue completely, yes i might help but i want to have a smooth gearbox as a Mercedes should!
But i am going to have the gearbox oil changed, and i will try look at linkages,
What else should i look at? i am able to get it on a ramp.
I believe the van has a recon gearbox and the vans previous owner from new used it around London so lots of start stop.
Id really appreciate any help and advise!
Thanks Arthur
Thanks Arthur
