- Dec 29, 2013
- Location
- Kidderminster Worcestershire UK
- Mercedes W124 260E M103
I am in this hole right now , Car failed to start other than a hum from the fuel pumps .I have never had a noise like it so i thought fuel pumps gone. ,. Both pumps changed and right away engine started .Packed tools away jub well done so i thought ..So just now i go out to try the car,, and yes you guesed it it wont start ...only with starter fuid ,,removed ovp and fuel pump relays a put in a good used ones ..Still no start .So pulled the feed for the fuel injection distributor and put the pipe in to a container . Switched car on spun it over no fuel came out of the feed pipe .So problem must be in the rear end with the pump set up .I was thinking fuel filter but it is not that old .Any ideas ?
