carat 3.6
- May 11, 2011
- Location
- In the workshop
- S124 E300d wagon, W124 om606 monster, E46 v8 coupe
Yesterday- Tuesday i went to stert the car up after 3 days ,and it started right away stumbled, and stopped.But started again right away .. Have a new fuel fiter on its way, it should come to-day. I will get that fitted along with the original accumulator i keep after i fitted a new one 5 years back at the same time the filter was fitted .Get earths checked at the same time . Keep looking in for further news .Mobile thingamabob will be here Thursday to do it.
The way your describing this fault I'm going to say it isnt a blocked filter or any sort of mechanical fault with the fuel system. The fact that it stops and then immediately restarts leads me to believe the fuel pumps are loosing their power.
Knowing what I do about these cars a bad earth for the pumps is possible, but very unlikely.
If your happy that both pumps are working as they should, either the live feed to the pumps is dropping out because of a fault at the relay, or another possibility is that the engine management itself is loosing power.
As this is an intermittent fault if I was going to try to pin it down further I would install some temporary test lights, one at the round plug I mentioned on the live to the pumps and another on the trigger wire to the fuel pump relay. Make sure you can see them from the drivers seat, that will give you an indication of what is happening in real time when the fault occurs.
