carat 3.6
- May 11, 2011
- Location
- In the workshop
- S124 E300d wagon, W124 om606 monster, E46 v8 coupe
Black pipe with a red trace is normally on the gearbox line, but the only way to be sure if it is part of the evap system is to follow the vacuum lines. I doubt any part of the evap setup is causing your starting issue though.Carat 3.6 The part is for the EVAP sytem ..this part is making a whering noise .So i do need to test it . Never noticed it before with the heaters on . so i dont know just how long its made the noise . Cars stood for 4 days ..It was a hard start to -day . it was a test to see how it did start ..just as i though not good ...
Did you check if the fuel pumps are working when they should be?
