peterg1
I will try to be succinct with this so here goes:-
Car - 2009 A 180, petrol with BRC lpg conversion (inc valve lube kit) 80,000 miles pretty well trouble free until a couple of thousand miles ago.
Fault - ocassional misfire on starting from cold which also closes down cylinder 1 making it undriveable on some occasions, ie very obvoius rough running and struggles to pull away. However on stopping after only half a mile then restarting it runs fine, despite this it is still usable as my daily car.
Action so far - i have my own code reader so i know it is allways cylinder 1 misfire when reading the code fault. The amber EML comes on almost every time I start whether it misfires or not, so it is a consistant/persistant fault.
First stop my regular MB specialist, they diagnosed unburnt fuel as the (probable) cause, changed spark plugs, fault still there, changed coil pack fault still there, they advised having the lpg system checked out. Note: Obviously this is a pure running on petrol fault as, a) it starts up on petrol, and b) I did try running the gas out and using exclusively petrol for a time but no change. Their theory was that it could possibly be taking air in somewhere.
Checked out by my regular auto gas specialist, run through all the pressure tests, everything fine, and their diagnosis was valve recession probably exhaust valve cylinder 1.
Having researched this it does seem plausible but at a repair bill well into four figures I'd just like to make sure I've covered all the options and possibilities?
So folks any other ideas? Such as could it be an engine managment fault, as it appears the fuel in is okay, the electrics (plug and coil) are okay, so by process of elimination what's left? Would a MB main dealer have any better diagnostic equipment?
I have tried to explain it the best I can but I am not in the motor/engineering background so please take that into consideration when reading this, (or replying). Basically a middle aged discerning motorist who went from an lpg Corsa to the A Class, to get quality with economy! Thanks Peter
