Journey home tonight was fine - until almost home then I tried an quick pull away at a roundabout and the car didn't take off.
Just plugged her in and trouble code P0304,0305,0306 are being reported (Misfire on cylinders 4,5,6). Aside from the fact the car won't rev - it is driving normally when you take it easy. MAF was replaced 6 weeks ago and I did red-line it last week and all was fine then.
All sensor reading look fine and 02, fuel trim etc is pretty close across both banks.
As the car is running fine I'm a little puzzled - what's common to one bank that could be causing this.
Also which bank is 4,5,6 - driver or passenger?
