My ABS light is now on and Cruise control and Run flat are both showing inoperative. I've done a quick check with my 'cheap' diagnostic tool and the only code I'm getting is U1409 that Google suggests may be 'Implausible Left Front Wheel Speed Signal Received'.
I have checked the physical condition of the wheel speed sensor cable and plug, which all looks very good.
What should the resistance be across the 2 pins?
I have also read that the brake light switch is a common cause.
Do I change the BLS first as it's cheap or go for the Wheel speed sensor and if so are non-OEM sensors a sensible option here.
