Ml270
wildthing78
ML270
Done a search but can't find anybody with the same problem.
Basically heated seats stopped working after drivers side burnt a hole in the leather. The cusion and element was replaced and connected but niether heated seat has worked since.
The buttons on the dash light with no flashes, just off, to 1 lit to 2 lit then off again, and the seat movement / tilt controls work perfectly.
Any ideas ?
TIA
You need to put the car on star.
Guessing will not pin point the problem.
Have you checked the fuses?
Regards
dokalj
