reedybopper
When I last posted, I had explained that I changed the battery on my W202, after which my car has now started to cut out when pulling upto junctions. This has now resulted in me driving with a heel and toe configureation. Once the car has warmed, it will tick over, but very erratically. from 100 - 1200rpm constant. The car performs well enough, but will cut out at junctions etc.. as i have just explained.
I was adviced to change/check the OVP Relay, I have just bought a second hand unit from MERCMAN, (and he assures me that the car it came off was running fine), but there is no difference! I was also advised to check the relay switch in the boot next to my battery, which I did, and all the contacts seem to be in perfect condition.
Can anyone offer any advice, my car is due in for MOT next weekend, and I feel this would not pass if will not tickover during CO2 test.
Many thanks in advance as I know you will respond.
Cheers
Cheers
