mccarthy
Hi all.
I decided do fix up a 2001 c200k w203 with a long list of faults so if anyone could help with the following. Passager side mirror indicator and mirror motor is not working I've checked the bulbs with swapping them to the drivers side and all fuses and no joy. I've an srs fault up which I think is caused by the drivers seat as a mount underneath is missing on one side allowing it's to move around. I have this coolant and washer lever fault even after changing both sensors and I've not noticed the radiator fan running even with the coolant temp up to 90 degrees. My obd reader tells me that I have a p0401 lambda sensor gone number 2 after the cat and my mass air flow reading does not change from 10.83 is this correct.
Thanks in advance.
Thanks in advance.
