My SL500 R230 currently has the standard NTG1 Comand system. I have the Bose upgrade parts and want to use those, but with a different Head-Unit. However, I'm still unsure of exactly what is where and could do with some advice (yes more, sorry Richard
I have all the Bose parts to install, but what will I then have and what function will each part perform and with what connections. Currently I believe there is the AGW behind the seat and there's the HU in its obvious location. Where's the navigation processor (and DVD?)? Behind the seat? In the boot? Combined in the HU?
I believe the Bose amp connects to the MOST fibre optic, but does it actually receive its audio signals in that way, or are there also analogue line level signals from elsewhere? The AGW? Or does the Bose amp replace the AGW?
Where will the actual audio signals be generated and how do they get to the Bose amp and how many channels are there? I suspect just the 2 (L & R) in the SL and the Bose then powers all its speakers, which are? Main ones in each door plus some (small ones) across the back behind the driver and passenger and the sub. But does the Bose system normally also power the centre one in the top of the dash?
In order to replace parts of the audio system, one has to know how the current system functions and I am still missing some vital information (although some of it is simply forgotten). This is something I've had on the 'back burner' for far too long and I'd like to finally do something about it. But I could do with more information. Is there an actual diagram I can download that will show exactly where the components in my car are located and how they interconnect?
