Multiple engine warning codes 06 cls 320 cdi
Well played Sir !
Remove the exhaust back pressure sensor (by the turbo ) and give the underside hole a spray clean (24mm deep socket, don’t drop the chrome washer underneath it !)
If the pcv tube is original (the orange seal at the end that goes into the batwing hasn’t got a silver clamp on the orange seal ) , it’s worth changing to stop more oil blowback going through the turbo .
Will definitely be doing this, nice one for the advice and tips 😁👍 spot on.
Well Fellas, all in all its been a good day, fuse 44 was blown replaced and did the resistor mod, once i did that all faults were cleared but the turbo actuator flagged up, rang about everyone I spoke to wanted me to buy a turbo, found a lovely thread on here that instructed me to solder broken links inside the actuator (Only one was at fault) put it all back together all cleared cost me 58p and runs like a dream, boy she's got some power, ordered new turbo and breather seals as they were slightly perished but I'm a happy man (child at heart) going to get her serviced in a couple of weeks and hopefully all being well I know where I'm upto.
I would like to thank you all for your time and comments, I will definitely be sticking around on here, good community and good people 😁👍
pull the egr and clean that too.
