My roof is stuck
abker
I have a 2003 clk 320 covertable and the roof is stuck can I manuly close it
Yes, there wil be tools to do this in the boot.
Do you have the owner's manual?
If the soft-top cannot be closed automatically, check the following points:
  • Is the boot separator engaged more?
  • Is the skibag cover* closed more?
  • Have the roll-over bars been activated?
  • Is the boot lid closed?
  • Is the on-board voltage sufficient?
    Start the engine if necessary.
If automatic operation still does not work, the soft-top can be closed manually.
This work must be performed by two persons.
The soft-top emergency operation is a complex, technically sophisticated process which requires a great deal of force. Close the soft-top manually only in extreme emergencies. In this situation it is better to get in touch with a qualified specialist workshop, e.g. a Mercedes-Benz Service Centre.
roof stuck
Hi folks managed to solve the problem One of the silver fold in buttons got stuck Sprayed with WD40 working fine now Iam glad it did not rain.
Thanks again
