JazzyJames2001
- Jun 8, 2008
Hello all,
Ive nearly completed my first LPG Conversion.
But Im stuck on a few items. Its a W124 with the M111 engine the 2.0 16v version.
Where is the TPS or Throttle Position Sensor?
Where is the best place to get a Ignition Live in the engine bay?
Am I right after checkin through the Haynes that the ignition coil is on the top of the engine? Under the metal plate that comes off?
And finally the Lambda sensor wires, on the left hand side of the engine, there are 4 wires, Black, Grey and two whites, the black splits off and the white and gray go to the ECU, correct?
Cheers All
James
Cheers All
James
