I'm replacing the rear sub frame on my 2013 CLS estate (X218). The brake sensors have been unplugged, the discs have been removed and the calipers are tied up. The parking brake has been disconnected.
I am trying to remove the rear flex disc, I've taken out five of the bolts and now I need to rotate the prop shaft to get at the others. However, it won't let me disengage park, it keeps asking me to put my foot on the brake, which I have (fairly lightly). Is it going by the brake fluid pressure? Do I need to put something in between the pads to generate some pressure when I press the brake? I daren't start it, the exhaust is off, I'm afraid the ECU will shit itself.
