- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
As per the title.
Friends had a Nest 3 smart thermostat installed yesterday and all seemed well when the Electrician showed them how the system worked. However,later that evening, the central heating did not turn on at 16:30 as scheduled, it did however turn on at 17:30 when the hot water was scheduled.
The App showed that the heating was on at 16:30 but the boiler did not run until an hour later when the schedule called for water heating. The central heating then worked until the hot water schedule finished at 20:00. The only way to keep the central heating on was to use the hot water boost function on the App or by pressing the button on the heat link controller box. It is an Ariston 30Kw boiler (not a Combi type)
They have left a message with the Electrician but haven't heard back from him as yet.
Are there any obvious wiring checks I can make? They are not skilled in DIY
TIA
TIA
