will it not move at all,what size wheels did you put on the car,maybe the tyres are too wide,or the wheels to big,might be stuck against the inner arch
yes it was moving perfectly before with the old alloys on there, ive just loosend the bolts and span the wheel and it moves fine... would i need to get shorter bolts from mercedes?
If the wheels wouldn't turn then the bolts must have been jammed against something - check for damage. Many people did expensive to Mercs when they fitted space-saver wheels and standard bolts, rather than the shorter ones that should have been used.
