Dear owners and experts, pls help a new cab owner on suspension issue.
I just got a 2001 clk230k cabrio recently and previous owner had bilstein shocks and koni springs installed. Now the ride is low and stiff, front chamber also way off so I am planning to restore it to factory spec. Problem is cabrio was never offically imported by MB in my country so no parts are available.
I found a few sellers on UK eBay have the spring but shipping cost is tooooo much , us$150 to ship one single spring. I don't think I will be able to spend over us$600 just on shipping.
Here is my question, one of the seller has this decription below. Does this mean I can get spring from the stated model and it will fit my cabrio? E-Class spring will be quite easy for me to get from spare parts dealer.
Any suggestions? Thanks alot!
Chuck
Brand New OE Specification*FRONT*Mercedes Benz CLK200 CLK230, item number 390389355195
Convertible*Kompressor*(97-02)*E200 E220*E230 E240 Komp.*(95-03)*SLK320 (00-04)*Coil Spring
· Original Specification unit
· Brand New with 1 Year Unlimited Mileage Warranty*
· Manufactured to OEM standards and designed to conform to TS 16949:2002 / ISO9001:2000 standards.
· The materials used in manufacturing must meet the standards (TS 2500, DIN17223, DIN 17224) and inspections are carried out at the factory to check.
· It is important to note that springs should always be replaced in pairs. Different springs on the same axle can have a negative effect on the handling.
Technical info and references:
Lesjofors (For Reference Purposes Only): 4056823
Fai (For Reference Purposes Only): SP168
Application: (627220590)
MERCEDES-BENZ CLK 208 200 06/97 - 06/02 F
MERCEDES-BENZ CLK 208 200 Kompressor 06/97 - 06/00 F
MERCEDES-BENZ CLK 208 230 Kompressor 06/97 - 06/00 F
MERCEDES-BENZ CLK Convertible 208 200 03/98 - 03/02 F
MERCEDES-BENZ CLK Convertible 208 200 Kompressor 03/98 - 06/00 F
MERCEDES-BENZ CLK Convertible 208 230 Kompressor 03/98 - 06/00 F
MERCEDES-BENZ E-CLASS Estate S210 E 200 06/96 - 08/00 F
MERCEDES-BENZ E-CLASS Estate S210 E 200 Kompressor 06/97 - 03/03 F
MERCEDES-BENZ E-CLASS Estate S210 E 230 06/96 - 06/97 F
MERCEDES-BENZ E-CLASS Estate S210 E 240 06/97 - 03/03 F
MERCEDES-BENZ E-CLASS W210 E 200 06/95 - 08/00 F
MERCEDES-BENZ E-CLASS W210 E 200 D 01/96 - 03/02 F
MERCEDES-BENZ E-CLASS W210 E 200 Kompressor 06/97 - 03/02 F
MERCEDES-BENZ E-CLASS W210 E 220 D 05/96 - 03/02 F
MERCEDES-BENZ E-CLASS W210 E 230 06/95 - 06/97 F
MERCEDES-BENZ E-CLASS W210 E 240 06/97 - 03/02 F
MERCEDES-BENZ SLK R170 320 03/00 - 04/04 F
Chuck
