Eddiemc11
Hi folks
I'm New to the Forum and if you guessed I have a problem with my new to me c220 deisel
I have good general car knowledge but very little specific to mercedes.
I've picked up a 2011 c220 deisel, it had warnings on the dashboard but i took his word that it was just 2 faults.
1 abs sensor, didn't know what corner
2 dpf needed resetting after changing the sensor.
So I have found the that the ring on the nearside rear is almost complete gone.
And that the fill level for dpf is at 345%. Car was not in limp mode and seemed to drive fine.
I've done a Forced regen and was able to see it clear some soot and drop to 0% on the scan tool I had borrowed,,
Eml light has stayed off so far with about 100miles done.
But I am now having running issues, the car seems to rev slightly erratic at low speeds. And gets a bit jerky when it happens,, also at times feel like it won't rev up unless I change down gears etc.
(manual gearbox)
So as I have not gotten around to changing the abs ring and the esp lights etc are still on, could that cause the running issues or is there another likely cause?
Thanks folks
(manual gearbox)
Thanks folks
