New Windscreen
zipdip
Essex
s320
Well heart in the mouth time my W221 S320 is having a new screen fitted,it has taken him a hour to remove the old one,this entailed using a weird contraption of wheels and pulleys and yellow twine to try and free the screen they attach it by suction on the inside of the screen and then sort of wind it to cut through the sealant ,that did not work so using wire and a sawing motion at last the screen is out no damage so far,not sure it is a positive but I noticed with the bonnet up there is a oil mark on the engine cover at the back so I will book it in for a minor service and get the Indy CCC at Colchester to sort that as well,well he took another 40 mins to fit the new screen and trim,I also fitted new wiper blades while they were off the car ,everything seems to be working so job done:D
Which company did you use?
The issue about Autoglass (and other large chains e.g. Kwik Fit etc) is that the quality of the service can vary and depends to great extent on the individual dealing with your car.
So it can be a bit of pot luck... I have seen some very good Autoglass fitters and some not-so-great ones... but the good ones are usually very good and very experienced.
