PrivateHireGuy
As per title really.
2019 300 E SE.
Ta.
2019 300 E SE.
Ta.
but ethically is it fair to increase your cars burden on the environment and others health to save yourself a couple of pounds a fill?In a nutshell, yes.
Modern engines are increasingly designed to reduce NOx emissions (among other things), and it's relatively easy to regain mpg and/or power losses via a remap that increases NOx emmision levels above the manufacturer's spec for the engine but below any legal threshold.
Modifying any part of the emissions systems is illegal and would render the car illegal for use on the public roads. MoT failure (not sure how it would be detected) and would render one's insurance void, easily detected should the company wish to investigate, to avoid paying out a big claim, or to recover costs from the insured
2019 300 E SE.
Ta.
In a nutshell, yes.
One issue to consider, is that remapping isn't cheap, and the economic viability needs to be checked by comparing the estimated overall saving in fuel cost against the cost of remapping. This isn't straightforward though, because too many remappers advertise unrealistic gain figures (for both bhp and mpg).
Scolding no one, just stating possible consequences/implications.Personally, I think that remapping should be illegal (as well as any other modification that alters the car's emissions), but given that it isn't, we shouldn't be scolding those who remap their car's engines.
Despite it being one of the reasons ICE is being excluded from cities. Or is that part of the game plan to accelerate the eradication of all ICE - even untampered with ones?Personally, I think that remapping should be illegal (as well as any other modification that alters the car's emissions), but given that it isn't, we shouldn't be scolding those who remap their car's engines.
Not necessarily true as a less stressed larger engine can have lower NOx than a smaller (esp turbocharged) one and it's NOx that is problematic in cities.Yes, because it's no different in essence to someone buying a 6.2L AMG, or driving an old Diesel car, the cars will release more emissions than other smaller or newer cars,
I suspect that it is illegal in that the vehicle is supposed to adhere to its homologated emission levels throughout its life. In essence, it should, at any point in its life be able to pass the original test for homologation were it submitted to it.so we should discourage their use in city centres, but as long as it's not illegal we'll just need to tolerate it. That said, I'm all in favour of making remapping illegal, just as PDF removal was made an MOT failure.
In an earlier post (on another thread) you said that larger engines should be penalised over smaller ones. Unfair if the larger engine (with say, half the mpg of the smaller one) only covers half the mileage of the smaller one - a very plausible scenario.
Not being capable of that a vehicle should be submitted for IVA (Individual Vehicle Approval) and will be allocated emission status in accordance with the supporting documentation ie, the results of the EU test it has subsequently been subjected to. As that is impractical it would be classed as 'emissions unknown' which places it in a much costlier VED bracket and may make it hard to gain insurance.
That it is never enforced is moot. The emissions originally homologated are expected not to be exceeded - and obviously re-mapping inevitably raises NOx output beyond any homologated limit. Thus, the vehicle is no longer EU compliant.
If a remap took the engine-out NOx beyond say, EU6 limits, then the car is no longer EU6 compliant. Doubtful that that is entirely legal.I am not sure that private owners changing the spec that their cars were tested with is currently prohibited.
Only because the change is unmeasurable. Can said kit be optioned at time of vehicle purchase included in that single transaction or is its sale a separate transaction? I'll wager the the latter.The obvious example if fitting larger wheels with wider tyres, which affects emissions. Not only is it not prohibited, but you can actually buy it as an aftermarket kit directly from the car manufacturer, and it won't alter the car's classification for VED purposes.
Altering the emissions by tampering with emissions kit is obviously a crime in itself but what happens within the engine (that is affected by a remap) should also be scrutinised.You could argue that it should be illegal, and I'd agree with that (or at least that it requires the car to be reclassified).
But as things stand, cars are being taxed based on the spec as supplied from the factory, and changing these spec is not in itself illegal, other than were specifically stated (e.g. PDF removal).
