Uky
- Jun 23, 2006
- C238 AMG
What happends is that when starting the engine, there is a lot of condensation forming in the exhaust system that gathers
in the lower parts of the rear mufflers. When the driver then uses the brakes, the (cold) water rushes forward where it hits
the (warm) NOx-sensors resulting in sensor failure.
Following the failure of a lot of NOx-sensors, Mercedes released a service information sheet: Small holes (~3mm) should be
drilled at the lowest point of the rear mufflers. This will make condensated water to get out safely, preventing it from
reaching the NOx-sensors.
I did that myself on my C238. Watching outpouring water forming a large puddles on the garage floor was quite an experience...
