gibsonk
I had been planning my dashboard facelift for a little while but though while i was at it i would drop in a ntg5s1.
The dash was surprisingly easy and i have zero creaks or squeaks, the only issues i have is i need to repin the wiring for the hazard switch and source a new glove box as it is different.
Fitting the 5s1 was a bit more difficult due to the screen size.
I intended to use a W212 screen and place of the w204 one, while this fits perfectly with the outer diameter the depth is wrong and you cannot fit the dash trim, my plan is to use the outer housing from the w204 and transplant the w212 lcd over , hopefully giving me a correctly fit screen, it seems the NTG5s1 is higher resolution than the 4.7 i had previously using the pre-facelift dash and flip up screen and better resolution than the facelift w204. For now however i have mounted a 8" display from a CLS and it doesn't look too bad.
There was a lot of re-pinning required on the quad lock and new wiring for power\ground also it required DOIP wiring installing to the ODB port to allow firmware updates and manuals, you can diagnose it over CAN but any updates will cause the Comand to get stuck in boot loader.
Only three things don't work so far, if anyone has any knowledge or advice it woudl be great
1, The online component doesnt work, i also expect it may never work due to the veedoc requirements
2, The other i woudl like is the Vehicle dynamics screen, BHP and Torque meters, the battery and Temp work fine just no response from the power meters.
3, Mirror Link, Carplay and Android Auto are not working, it just asks me to plug into USB port 2, i believe this is because i need the USB hub that sits in the arm rest and wiring
If anyone has anty knowledge of these three items and how to fix them i would be extremely grateful.
