currycowboy
- Oct 5, 2013
- Ml 270
Bought myself an ML 270 2001 british registered car in spain for use getting out and around rough terrain. I live in a very hilly area (near Riogordo, Malaga) on a dry river bed, which undulates over rough shingle and rocky ground which i thought the ML would be great for. Its an old car that has covered 143k and hasn't been maintained very well if at all. Cars are extortionate in Spain and this is all my budget could suit at €1200, which i thought was cheap and am gambling the fixes are not going to double the price!!!
The dashboard lights are lit up like a christmas tree. ABS, water level/temp, sensor esp, airbag all lit. There is no kick down and on inpection the kick down switch seems to operate mechanically although I havent used a multimeter on it as I dont currently have tools out in Spain and will be taking them with me next time I go. There is a lot of float in the accelerator peddle left to right (seen fix for replacing plastic pin for bolt and will do that when i get out to spain in few weeks). Am on here predominantly to try and get info to fix it, so I can amass necessary parts in Uk which will be cheaper than spain and take them with me.
The car seems fairly gutless in drive, is better in Tip and in low range. When in Tip shifting down it does seem to emit more darker emissions but when revved in park doesn't seem to be excessive, usual diesel look and no major engine noises. In drive I am only reaching 40mph on inclines etc revving only to about 2500-3000rpm.
I bought the ML through a 3rd party and the owner states that Mercedes told him there is likely a valve issue on outlet on manifold that needs cleaning. Can anyone shed light on this also please and how easy/difficult a repair to diy fix, if indeed this is the likely reason for lack of power etc. I thought maybe it may have been MAF sensor prior to this revelation but am clutching at straws as have no knowledge whatsoever on Mercs, this being my first. .
The radiator fan is not working but temp seems to be stable around 80-85 coolant level is correct. I need to sort this though as I dont want anything to cook when its hot again, also would be nice for aircon improvement as o.k when moving but warm when stationary!!
Needs passenger mirror assembly has back casing only and needs drivers side casing only, aint they kin expensive!!!!!
Havent inspected gearbox whatsoever so wouldn't know about ATF drain top up if there is a stick or measured amounts so any info on that would also be greatly appreciated.
The car is surprisingly complete with only a few battle scars for a Spanish car (they are normally dented about all over, so would be nice to get sorted, being a 7 seater will be really handy to collect relatives from the airport or anyone on this forum who fancies flying out to fix it lol.
I have purchased oil, air and oil filter and intend changing (with my tools on my next trip out there). Where is filter housed on these (only had 5 minute look when i was there and couldn't see it).
First post and welcome sarcasm piss takes etc as well as some help which I am sure will be in abundance
