Sp!ke
Administrator
Driving into work today and was fine for the first 20 miles or so and then I went to pull away and the car stalled.
Tried to restart it and it reluctantly started after about ten seconds on the key. Normally its immediate.
Anyway, tried to pull away and its lumpy as hell, I found that if I am very gentle on the gas it would pull away OK but if I put more than a little pressure on the pedal, it would misfire and try to die. Once moving and the revs up a little, the car ran normally with little or no signs of problems.
I limped to work and parked up I've just been out now and looked for anything obvious but couldnt see anything but the car now refuses to start and the battery is showing signs of being on the low side as after only a few seconds on the key, it started turning over more slowly.
Does anybody have any ideas on this one? It feels like fuel starvation but I can hear the fuel pump turning. I was thinking mebbe alternator/battery (no lights to indicate this mind). I also thought mebbe my cat has finally collapsed and is blocking the exhaust or something unded certain conditions.
If the car had a carb I'd say it was the idle jets that were blocked - is there similar on a injection system?
