Oil leak on a 2006 cls350
MWCLS
Chelmsford
S320 CDI Perlite Gray Metallic 2005
Just after a bit of advice, I hadn't driven my car since Saturday, went into the garage this evening after backing the car out noticed a small amount of what looks like engine oil on the ground which has come from the front passenger side.
Anyone had anything similar or could shed some light before I take the car to a garage for investigation. Any advice very much appreciated.
Michael
I think I've hopefully identified my minor oil leak, a little big of research on Mbworld.org appears to be a leaky cam plug very slight but there all the same pretty common on the 272 engine, ordered them today so should hopefully be resolved shortly!
Loads of issues on M272 engines, particularly early ones with timing gear, cam chains, tensioners etc. Get researching and get fixed.
