I am hoping someone will be able to help me with a little oil leak problem I am having with my wife’s W204 C250 MY11 60k.
I recently changed the oil and filters as usual. Measured and replaced with exact quantity of new oil using; Fuchs TITAN GT1 PRO FLEX XTL 5W-30 Fully Synthetic Engine Oil and a BOSCH Element Oil Filter F026407112.
On initial inspection it appears to be leaking around the top of the engine under the plastic cover. There is evidence of oil spray around the oil fill cap and a lot of oil sitting in the channels around the top of the engine and on the fuel rail.
I need to run the car to see if I can diagnose where this is spraying for but it has lost more than half it’s oil over 3weeks and there is oil all over the drive and road..
Is there anything oilwise around the top of the engine that is prone to this type of failure?
Many thanks in advance,
Regards, Neil
Regards, Neil
