om606 n/a to turbo put into a e320 w210 HELP
willemse
1996 e320 and e300d
i have bought my first 2 benz
1996 e320 and a 300d with the om606 here is my plan
e320 has perfect body with slk55 rims the 300d is a rust bucket but underneath a beauty
both have blown head gaskets .
now here is what i want to accomplish
e320 pull motor put the om606 in it with a turbo bolt it up
i dont know if both the trans are the same another question is the wiring the same or will i have to do a complete loom swap?
inter-cooler and a upgraded injection pump and a 6speed manual if i can if not a 5 speed will do but i have no clue what will work with the electronics or if i can go mechanical on the injection pump and standard on the 5 speed
recommendations please!!!!!!
turbo
inter-cooler
injection pump
trans
and any thing else i am missing
1996 E320 - W124 or W210, petrol or diesel, estate or saloon, auto or manual?
None of your questions is answerable without more info
Nick Froome
you need to get reading on superturbodiesel.com
All answers there - you have alot of work ahead of you with the conversion.
Fit a mechanical OM603 pump to the 606, along with the manual gearbox, that way the engine / transmission do not need to be connected to the loom (for any control), just connect up the sensors as they are all identical bosch across both engines.
You will then have to just take out the BAS/ASR lightbulbs in the dashboard cluster then you are good to go, I say all this because swapping the looms will take you years to sort out and then it still won't work..
H
