Gnasher141
First small mods with before/after data:
Bit HarshDont take this the wrong way but what is the point of asking the same questions over and then not taking the advice? Remove the intercooler pipes and fuel filter pipes and all is open before you do it buy the turbo inlet and pcv valve seals to replace them also buy yourself the green intercooler seals and replace those, thats it, its an easy job just make sure you buy the correct stat some have a preheater which is a black plug on top some dont
