CumbriaNeil
Evening all, I'm new here but have been using your useful threads for a few years now so thanks for your previous help and i wonder if you can shed any light on my specific issue, I can't see any similar issues discussed.
I have an S212 with an OM651 engine, it has now done 135K but has always been serviced by MB. A few years ago I noticed a problem, over the last 50k it has been getting worse. To the point now where the symptoms are clearer and I need to sort it out.
When sitting on idle, some of the time it periodically dips the revs. Sitting merrily on 850 then for no reason the revs drop for a fraction of a second before returning to 800. When it does this it does it regularly, say every 10 or 20 seconds and it doesn't go away. when driving the car at anything over walking pace there are no symptoms and it behaves perfectly in all other ways. I think it does this more when it is warmer outside or when it has been on a long run but I haven't pinned that down accurately yet. Also a couple of times when it has been re-fueled it has made it worse.
Recently, as the problem has become more pronounced, the drop can be quite severe with the needle flicking down and then returning and the car jerking if it is in gear. As the problem has gotten worse it has started to stall occasionally when it is under a little load like going around a car park or just as you are about to accelerate away or you come to a stop. It happens whether it is in gear or not but seems to be more pronounced when it is in gear, I assume because it is under some load.
The engine warning light comes on sometimes but not often and clears itself usually the next day. My local independent MB specialist suggested that it would be the EGRV and that I should get a clean as a first stab but he couldn't see any error codes when I took it to him. Since then I have bought a cheap code reader and it gives me the following codes:
P0087 - Fuel Rail/System Pressure - Too Low
P0252 - Injection Pump Fuel Metering Control A Range
P0088 - Fuel Rail/System Pressure - Too High
I have a suspicion about what it might be but thought I would see if any of you more knowledgeable folk have an idea before I start spending money! Any ideas please?
