P0301 cylinder 1 misfire detected
VW1300_1974
I've got this fault code on my C180 (1998 model).
My first guess would be the coil-pack, but if this was failing wouldn't it cause a misfire on two cylinders as they share a coil?
What else could cause this fault?
Also, which is cylinder no1?
Many thanks
Cylinder No 1 is closest to the radiator. Your problem could be that the coil pack extension (the rubber bit under the pack) is time expired and requires a new one. Cost if I remember correctly is about a fiver.
Could also be sparkplugs or lead I find the plugs only do about half miles that Mercedes say.
Good luck
Ron
Thanks, I'll have a look at the lead first.
