P062B
Frank3
Wn5 9ul
Mercedes e220 w212
Internal Control Module Fuel Injector Control
Where abouts is it under the bonnet.
That code does not mean much from that description. What is the issue?
I had a few codes come up,MAF fault exhaust temperature sensor and this injector module
Hello Frank , my name is Petrol Pete, welcome to the MB Club forum. I trust you had a nice Christmas and I wish you a Happy new year.
P062B.? No frucking Idea
Hello Peter Happy new year to you too.see if this is what it means
It looks like you have a boost leak and an exhaust temperature sensor issue.
Hello
I ve ordered a new MAF
need to find the part no on the temperature sender unit before buying it
Hello
Why? You don't have any MAF codes.
Just because you have fault codes it doesn't mean you have an issue either with that component.
Before buying anything get it diagnosed properly. It WILL save you ££ in the long run. I'd use a good independent MB garage.
Hello
Thanks, I'll check all the pipes when I am changing the new sensor,which I know is faulty.
Thanks for your help
Make sure you get a genuine part. After market MAF's don't work at all on this engine. Also the air filter play a part in how they work and its good to replace this at the same time. The adaptation data will need to be erased after its fitted too.
Pete.
Thankyou for all your advice managed to find a mercedes specialist they found the problem, the MAF is going back.
Cheers
Frank , it was actually Olly that gave you all the good advice, but I am happy to bask in any spare limelight....:) Thank you 👍
