Part of console not working
blueeyes
As the title says really, the bottom centre of the front console on my mercedes e270 has suddenly stopped working. It is the esp, back headrests, hazards, and door lock on and i have no idea why.
can anyone shed any light for me please .
Cheers
awwww come on peeps, can nobody help me?
Welcome to the forum :)
Have you checked all the fuses? I believe there is a fuse box on the o/s side of the dashboard, near the door.
I would check you manual for other fuse boxes that the car may have.
Does the lower console lift up when you press a button? Also, can you still put a cd into the cd drive?
Once, you have checked all your fuses and if there is no problem and you can not see any damaged wires near the lower console control. Then the vehicle would need to go on STAR.
Unless, another forum has had the same issue and can tell you?
Have you tried calling your local indy if you have one? He maybe able to provide you with some advice over the phone?
dokalj
Dokalj,
Thanks for that, hubby had tried some of the fuses but he did them all and now it all seems to be working, thanks again.
No worries, anytime :)
