Parts ID please
Sagani
Norfolk
2008 Vito 120 CDI
Hi all,
Does anyone know what the two large rubber blocks are called near the bonnet hinges of a Vito W639 please?
They are there to either serve as a cushion for the bonnet or as a rain deflector, I'm not sure as mine are badly chewed up.
I've tried the usual parts diagrams, but I can't find them.
I'll try to add a photo of the position of the part to help ID
Sorry if this isn't in the correct section of the forum, I wasn't sure if it's classed as bodywork.
Si
Just go to your local MB parts department and they will identify them from their on line parts scemstics and order them for you.
It looks to me like it's item 45 in this drawing:
At any rate, if you remove it carefully, there will be an MB part number stamped on the bottom, similar to this one:
images
Thanks,
I think your right about being number 45. Its so badly chewed up that it doesn't look like that anymore, but probably did once 😜
I'll try to remove what's left and see if it has any codes.
Thanks again
Si
