I scrapped my little 2005 250k mile Citroën C2 1.4 diesel today after catastrophic gearbox failure.
As I had just filled it to the brim with diesel moments before it’s demise, I used an electric pump to drain the tank, and couldn’t resist adding some weight to the car as it was going on the weighbridge. Amongst all the scrap metal that I dragged out of the garage and thrown on the back seats I also decided to add some ballast to the now empty fuel tank.
This consisted of 25 litres of used engine oil, 5 litres of dirty cooking oil out of an old (now on in the boot) fryer, 4 litres of 2yr old manky petrol, and finally a couple of litres of sludgy brown diesel out of an old space heater.
I primed the fuel system and after a few turns it started. It ran absolutely fine. I let it warm up, still no smoke, no engine light on, turned it off, restarted it.
Eventually after approx 20 mins (I was doing other things too), it sounded a bit “knocky“. It would still Rev cleanly with no smoke though.
This would’ve done pretty bad things to the entire fuel system, mainly the high-pressure fuel pump and common-rail injectors, but it just goes to show how much the management system can adapt, to mask the effects of bad fuel.
It was still running ok after being yanked a few miles by the merc to the scrapyard where it was revved till it took its last breath and choked us all.
Small amount of petrol? May be ok but if you can drain it for reasonable cost, it’s not worth the risk is it?
