AngmarWitchLord
Ok guys, here's my problem
Just serviced the car myself and whilst I was at it I fitted a pipercross washable filter (because I KNOW I'll notice the extra 0.3 bhp
Anyway, coincidence or not, the car started acting very strange when I took her for a test run to my parents house 10 miles away.
The engine was behaving sluggishly, and if I floored the pedal, it had the same effect of slamming on the brakes and the engine began to die as if it was choked of air, making me immediately suspect carburation rather than ignition.
I hastily sent off an e-mail to pipercross to see if they had any opinions, but inn the meantime I put my Mann paper filter back in, lo and behold there was no change (I'm expecting to send a very apologetic e-mail to pipercross soon
I decided to have a look at the plugs as I knew they were due for replacement sometime soon and they do look like the electrodes are covered in groups of tiny pits. and the electrodes look quite worn, not like a new plug.
I only removed one side as everyone here with a V6 knows what I mean about it being one b*tch of a job.
I 'll also describe what happens with a cold start:
Engine will turn over and fire up ok, going to 1500rpm fast idle, but then will reduce over 3-4 secs and eventually cut out after some popping and farting.
After several attempts like this I disconnected the Mass air flow sensor in the air inlet pipework above the air filter compartment and the car then seems to start ok, going to fast idle and not stutering when reducing down to idle (althought this may have been coincidence as I'd attempted about 5-6 times to start)
I removed the mass air flow sensor and with the car at idle, I blew on the sensor, this had a similar effect like the car closing the throttle plate to compensate for the extra air flow and agin the car began to choke.
I think this probably eliminated the MAss air flow sensor from my line of enquiry, so what the hell is it?
Could my plugs really have such a profound effect on my cars' performance or is a trip to the local dealer for the dreaded "diagnostics -but we'll fit a new ignition system for you anyway as its sure to solve some problem somewhere for you sir"??
Someone must have an answer for me here.
I'm loath to fork out my hard earned cash whilst MB charge me to fit parts on atrial and error basis which I'm quite capable of doing myself, and I dont have to pay them a fortune for the privilege!!.
Ps this is getting embarassing as my girlfriends 2.5 Litre X type is top car again at the moment.
