Poorboy's world blue liquid wax.
OneForTheRoad
uk.
2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Hello, I bought 2 bottles last week . It's been left in my shed since I bought it . I went to use it today and it's separated in the bottle . Top inch or so is a dark blue watery liquid and the rest is a pale blue/grey thinnish substance .
Can I ask if anyone using this product if this is normal , it seems very watery as if it's been watered down.
It is very oily on the hand and polished up really well on both cars, After a good shake up.
I'm just not sure it's tampered with ,before I return it , anyone help.
Previous Poorboy's products have been like a shaving gel / cream . Not runny.
From their website -
"Liquid Natty’s Blue has the same properties of Natty’s Blue Paste Wax but is even easier to apply and remove. It can be applied by hand or machine and can be applied thinly due to it having a very thin viscosity."
Reviewers commented on it separating. Quick shake and all fine
Wonderful reply. That's put my mind at rest. Thanks.
I'll shake it and try it in the fridge .
Really common for products to separate a bit when they're sat around, the heat may not help much either.
If it works well and looks normal once you've given it a damn good shake I wouldn't worry. Even stuff like Super Resin Polish separates and needs shaking as you end up with the thin liquid at the top. I assume maybe it's the solvent part where the abrasive part sinks to the bottom. :)
