Can I ask what year? This model is a 2009I’ve got the same gearbox and engine on 133k with no issues to speak of ….(Possibly helped by excessive servicing though )
Every 35-40k miles on the gearbox .Thanks! How ofter are you servicing?
Same 2009 .Can I ask what year? This model is a 2009
Again that's something I would need to check on previous paperwork , TBH any used car whatever the model input in for a service on engine and gearbox. So any engine issues at all?Every 35-40k miles on the gearbox .
Only glow plugs which I change every 40k ish (£50 diy ) .Again that's something I would need to check on previous paperwork , TBH any used car whatever the model input in for a service on engine and gearbox. So any engine issues at all?
So does this model not have a dpf as standard? Or have you removed yours?Only glow plugs which I change every 40k ish (£50 diy ) .
Exhaust Back pressure sensor
Cleaned out the turbo actuator 3-4 times and sprayed cleaner into the turbo .
I have a resistor which bypasses the inlet port motor .
Cleaned the egr valve a few times .
My car doesn‘t have a dpf which keeps things simple .
Nothing else to speak of
Yep , not standard .So does this model not have a dpf as standard? Or have you removed yours?
It would be very very unusual for a car to have had the transmission fluid changed multiple times in it’s life time, even once is a rarity, so don’t be too concerned if there’s no trace of a transmission service in the service book or associated invoices.Again that's something I would need to check on previous paperwork , TBH any used car whatever the model input in for a service on engine and gearbox. So any engine issues at all?
Thanks for the update and perfectly fine for you to comment . I normally buy cars for cash from 2k to 3k majority Japanese and have had some great cars for minimal outlay. Was never one for finance but bit the bullet and can have up to 10k. I've have never bought your more high end motors such as Merc or Audi in 20 years of driving so thinking why not give it a go you are only here once. Not a fan of the C class styling but the CLS I do like, and for me this car is an entry into Merc's but I appreciate the honest responses from the members on this forum. I have been on many sites checking reviews and keeping an open mind , overall there are mostly positive , but as a few members on here have testified when certain parts go it is costly. The other option as you pointed out is buying a newer car but of course it won't have the fun of driving the CLS....my other potential vehicle on the hit list is a Honda Legend , seen one locally going for 4k...again expensive driving with tax and the potential for expensive bills.DPF was not standard; you are better without it.
Maybe not for me to say but I had always assumed that the logic for borrowing money to buy a car was that it enabled you to buy a newer better more reliable car with minimal repair bills which would then justify the (potentially high) interest charges. In your situation I would either be buying something cheaper for cash or borrowing a bit more and getting something newer / more reliable. If you need to borrow money to buy a 5/6k car then you are not going to be overjoyed by the £1k bills that these cars can land you with quite easily. Just a thought; tell me to mind my own business if you like.
