KLP 92
I have a problem with a 560 V8, the car has a miss. The miss isn't noticable when the car is idling in neutral or park. When i hit the gas, while the car is in neutral, i can feel the miss in the engine. As soon as i put the car in drive or reverse the car begins to almost judder with the miss. The car is also sluggish, doesn't drive like a V8.
The previous owner had tried to have it rectified and changed a new distributor cap, rotor arm, ignition leads, new plugs, new fuel injectors but the problem is still there.
I've checked the plugs to see if there was oil or excessive petrol on the plugs but they are all fine. The car's not using any oil or water and there is no mixing. The oil pressure is just under 2 when the engine is hot, so no problem there either.
Any ideas on what it could be?
