PSE Part No
JamesWardzala
CLK
I have an 04 CL with most and dvd command
Can someone please give me the part number of the replacement PSE required to run a UHI phone, the one i have at the moment is only for a 6310
Can somone please let me have the partnumber for the uhi socket that you plug the cradle of your choice in to . Located under the armrest
Regards James
Regards James
Before you go too far down the road of plug and play you need to know a few things first.
a. It is not plug and play at the PSE end or the head unit
b. there are wiring changes at the PSE end to the main harness
c. The armrest trim lining and the contact plate are plug and play
d. without the latest firmware in the head unit there is no chance this will work.
e. If you do not have voice control (standard in CL) then you will need that module also.
Shopping list
- UHI contact plate
- UHI armrest trim
- PSE
- wiring changes
- head unit firmware
- diagnostics work
- voice control (maybe)
Part numbers roll over rapidly. Just find the VIN number of a car with the stated features from factory and use that for ordering.
What year car should i get the chasis number from ?
Any ideas when the 6310 stopped and the uhi came in ?
The facelift models are MOST and the last of the series are UHI. The newer the better in relation to W215.
