R107 SL - Removing ABS Pump
mct_cars
Newcastle
Mercedes R107 500 SL
Hi All,
I'm going to tackle replacing the seals in my Brake Master Cylinder today. As I've got that out and need to bleed the brakes anyway, I'm going to remove the ABS pump to clear a blocked drain hole and give it a good clean.
Do I need to do anything special or is it just a case of bleeding the brakes as normal once re-connected?
