R129 brakes
Watchcame430
Previous 1994 SL500, 2001 W210 E430 and 2003 Designo S500 Current 2005 S211 E270
Hi All,
I need some rear discs and pads for my 1994 R129 SL500
Went on euro at parts and there is two different pads and two different discs without any reference to compare what needed.
Any one any ideas?cheers
Vin is WDB1290672F094343
Plugged the above details in (not the VIN), the differences are too close to be obvious, you'll probably have to use a tape measure to check.
Alternatively just order from your dealer, the brake parts are pretty competitively priced.
Thanks ... Was hoping to pick them up from an open ECP tomorrow. I think Texar are Oem anyway?
Don't have a dealer local but probably will order from a Merc dealer.
rear discs should measure 300 x 22mm
Thank you!
Discs A1294230012 and pads A0054201720
Euro:
Textar Brake Pads Part No.: 101220136
ATE Brake Pads Part No.: 101220135
Pagid Brake Pads Part No.: 101220138
Textar Brake Disc Part No.: 104220276
Pagid Brake Disc Part No.: 104220278
Euro:
Thank you so much!!
