R129mine
My Coolant was changed in 2007 when I purchased the car and again in 2017 (by MB in MK and Indie respectively)
I am not sure if 10yr interval is the correct one. I am trying to do the simple maintenance stuff like (oil, filters, brake fluid, spark plugs etc and disc brakes/pads) but will defer to the Indie for suspension and more complicated engine/gearbox matters and am wondering whether it is time to change the coolant.
This pdf indicates that the coolant should be changed every 3 years, and not 10 but it has been serviced annually by 2x different Indie's since 2009 and only 1 decided to change it in 2017
Just purchased a £8 Sealey coolant tester to check the Coolant status
a) Coolant is looking very clear and
b) gives me the best possible protection up to minus 40degrees Celsius so not entire certain whether to change the coolant or not.
If I do have to change it any good tips (will get the MB coolant from the MB dealer) on process (and do you mix it with ionised water? and what ratio should I use for UK weather
