Shadychris
!995 SL320 pre-facelift.
Sorry this is a lengthy one but wish to give as much info as possible about this headache of a problem
What I know:
Had a new Yuasa 5000 series battery fitted last November - charges fully to ~12.9V, battery indicator green.
With everything connected 'as standard', battery will drain to a point where it wont start after 3 - 4 days if not started and run for 20 mins or so every day.
Checked battery -ve terminal to ground with everything switched off (including boot light etc) and its leaking between 300 - 350 mA
Pulled all fuses and can measure about 20 - 40mA across fuses 8 & 9 in main fuse box under bonnet - likely combination of clock, stereo and IR remote control (odd that there is also another fuse (6) in boot for IR remote)
On fuse 6, in boot auxiliary fuse box I'm seeing about 300mA - so this seems to be the cause, as it seems to be generally accepted that the standby draw should be no more than about 40 - 50 mA.
What I've done as trouble shooting\elimination.
Checked alternator by running motor and checking at battery for any AC ripple voltage which would indicate bad diodes - nothing.
For good measure disconnected the dealer fitted retro factory alarm MBSS system under the bonnet
If I leave fuse 6 pulled out, the car will happily stand for a week or so without starting and still have more than 12.6V required to fire it up.
I've eliminated boot light - the switch works perfectly. To eliminate further, the central locking control\pump has been disconnected, as has the electric antenna, and for good measure the N26 ATA module (although that's on fuse 5) but I understand it interacts with the N54 IRCL unit on fuse 6)
However even with all that lot disconnected I still get ~300 mA across the fuse 6 terminals - the only thing still connected on fuse 6 is the IR control module N54, so it seems highly likely this is the culprit.
My problem\questions
My N54 module is not located in the boot above the CL pump and below the N26 ATA module - so I cant easily disconnect it. From the webetm Star Finder it appears that it is located deep under the dash on the nearside - and look to be a complete dashboard out job to access it :-( But the location on that photo is on a L\H drive car. So first question is will it still be on the nearside behind the passenger airbag - or does everything L\H drive model simply swap orientation to R\H drive?
Second question is about the module itself. If I can find it and identify that as the cause by disconnecting it and measuring across fuse 6 again, is it possible to simply get a s\h replacement N45 IRCL module and plug it in? Or is it in some way coded to the main ECM?
I have enough knowledge of electronics to know that my IR key fob has a set signal code, and that will programme itself to the IR receiver\control unit (as described in owners HB). But not sure if some ECM programme tweaking needs to be done to recognise a different IRCL control module??
Anybody have any experience of a) the exact location and how easy\difficult a job to get to it and b) whether a replacement module is just 'plug and play' ??
Thanks in advance!
What I know:
Thanks in advance!
