Martin968
Hi all
Having a strange issue with the mrs SLK320 facelift
I have serviced the car and replaced just about everything I could to make it safe and reliable but have managed to break it
The car is a 2001 SLK320 auto with 71k on the clock, full mb and indie history
I changed all the engine parts filters, oil, plugs and so on, including new belts, the gearbox was a bit jerky so that had a new filter and fluid and the plastic plug replaced
The car has been fine but developed the holding back at 4000 rpm problem, but that would clear if you kept you foot buried
This got worse and worse, tried cleaning the MAF no joy so I bought a cheapo one
This fixed the problem, it drove like a new car, this did not last long, ten days later and the car started almost stalling on take off, real hesitation, checked the codes P0100 circuit A fault
So I got another replacement MAF and that has been fine for 2 weeks, now it’s exactly the same again, hesitating and not pulling away cleanly
And I have the P0100 code back again
I am struggling to work out what I have broken
Any ideas accepted
Any ideas accepted
